Display the IP mroute Routes
Use the following procedure to display multicast routes ingressing on either SPB-PIM Gateway interfaces or SPB multicast interfaces.
The UPSTREAM_NBR field is populated only if the stream was learned across a spb-pim-gw interface, and the upstream neighbor is the PIM neighbor IP address toward the source. The PROT field equals spb-pim-gw when the stream‘s source is learned on a VLAN configured for protocol spb-pim-gw. If the stream's source is learned on a VLAN configured for spb-multicast, the PROT field equals spb.
Switch:1>show ip mroute route ================================================================================ Mroute Route - GlobalRouter ================================================================================ GROUP SOURCE SRCMASK UPSTREAM_NBR IF EXPIR PROT -------------------------------------------------------------------------------- 233.252.0.1 0.0.0.0 0.0.0.0 0.0.0.0 V3 30 spb-access 233.252.0.1 192.0.2.102 255.255.255.0 0.0.0.0 - 0 spb-network 233.252.0.2 0.0.0.0 0.0.0.0 0.0.0.0 V2 30 pimsm 225.1.1.1 198.51.100.99 255.255.255.0 0.0.0.0 V3 173 spb-pim-gw Total 4
Variable definitions
The following table defines parameters for the show ip mroute route command.
Variable |
Value |
vrf WORD<1-32> |
Displays the multicast mroute information for a specific VRF name. |
vrfids WORD<0-512> |
Displays the multicast mroute information for a range of VRF IDs.
Note:
Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
